CoordinationModelDB.pdb not loaded
Hey !
A'm new in Revit API and in C#.
I'm trying to  open Revit Model from MS Visual Studio :
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.OpenAndActivateDocument(@"C:\Users\PSPOD\Desktop\models\PM1.rvt");
Autodesk.Revit.ApplicationServices.Application app = uiapp.Application;
Document doc = uidoc.Document;
 When i launch it , i got an Exception:
System.NullReferenceException" in CoordinationModelDB.dll
 How to fix it ?
jeremytammik
Welcome to the Revit API!
I have never heard of this problem.
You may be doing something fundamentally wrong.
To get started with the Revit API, I suggest that you first of all take a look at the getting started material and work through the step-by-step instructions provided by the DevTV and My First Revit Plugin video tutorials:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That will explain all you need, including the answer to your question.
For a quick start, you can also check out the hello world examples in the developer guide:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_G...
Jeremy Tammik
Developer Technical Services
The Building Coder
Great thak you !
Hello @Anonymous  ,
I just had the same error. For a unknown reason, Visual Studio didn't load all modules.
If you are a curious being like myself, you can learn more the problem about this here :
https://stackoverflow.com/questions/24761938/breakpoints-not-hit-no-symbols-loaded
and then here :
https://stackoverflow.com/questions/12891167/visual-studio-is-not-loading-modules-when-attaching-to-...
If you just want to fix it - that's pretty fine too - you need to follow the steps to reload them :
"Finally I found the answer in this post. I took a look into the loaded modules (Debug->Windows->Modules while having assembly attached to process) and noticed that my actual assembly wasn´t in the list. The code I wanted to debug is built with .NET 3.5 but modules have only been loaded for .NET 4.0. Usually this might be detected automatically as far as I am concerned but however this time automatic detection did not work for some weird reason so I changed selected code type from managed (v4.0) to managed (v2.0) and now it works. Hope this won´t occur when I have to debug on .NET 4.0 later again..." by HimBromBeere
Or in detail :
https://stackoverflow.com/questions/2155930/how-do-i-remedy-the-breakpoint-will-not-currently-be-hit...
I hope that this will be helpful,
Have a great day !
