Convert rfa file to step
target1988
target1988
Good day,
I'm not sure if this is the correct forum to be posting to, but I need some help converting an rfa. file to a step. file. If anyone has a chance and is willing to help me out please.
I've attached the file to the message.
Thanks in advance!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @target1988 ,
Revit does not offer the option to export model to the STEP file format.
But there is a workaround to achieve what you want
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jeremytammik
The IFC file format is STEP based.
Jeremy Tammik
The Building Coder
target1988
Hi Naveen,
Thanks for letting me know. I don't have access to Revit though, and the file I posted came from a supplier who I can't currently contact. Are you able to convert it into a SAT file?
