Conversion from Deprecated ParameterType to ForgeTypeId and display ForgeTypeId?
stephen_harrison
stephen_harrison
I am trying to prepare some of my old code for the deprecation of ParameterType. Within that old code I obtained some data on Shared Parameters including the ParameterType:
ParameterElement paramElem = elem as ParameterElement;
SharedParameterElement sharedParamElem = paramElem as SharedParameterElement;
Definition def = sharedParamElem.GetDefinition();
ParameterType DataType = def.ParameterType;
This is then stored within a class list "ExistingSharedParameters" and contains:
public class ExistingSharedParam
    public ParameterType DataType { get; set; }
I believe this can be updated as follows:
ForgeTypeId DataType = def.GetDataType();
    public ForgeTypeId DataType { get; set; }
I Currently displayed these ParameterType within a DataGridView as below:
SharedParamDGV.Rows.Add(DataType);
However I am unable to display the ForgeTypeId as a meaningful string i.e. Length etc.
I am sure it will be a very simple answer but I am just not seeing it.
Any assistance much appreciated.
mhannonQ65N2
Use the TypeId property.
stephen_harrison
@mhannonQ65N2. Thank you for your response and I know I am being rather dense today but can you provide a little for detail as I don't see how that fits into the code I provided unless you are saying it needs a full re-write?
I have tried the below but it still keeps showing "Autodesk.Revit.DB.ForgeTypeId"
DataType.TypeId
DataType.TypeId.ToString()
Thanks again.
mhannonQ65N2
The TypeId property is a string. Just put it into the grid cell as it is. Try doing something like this:
ForgeTypeId ForgeDataType = def.GetDataType();
string DataType = ForgeDataType.TypeId;
    public string DataType { get; set; }
It's hard to say more without knowing how exactly you populate your grid.
stephen_harrison
@mhannonQ65N2. Thank you for your response your proposal of
 This Is the same as my thoughts which I had tried and didn't work
DataType.TypeId;
The result is ""autodesk.spec.aec:length-1.0.0".
There must be a way other than using split string to get length?
mhannonQ65N2
"autodesk.spec.aec:length-1.0.0" is the 'official' name for it. You could use LabelUtils.GetLabelForSpec(ForgeTypeId) instead of TypeId to get the user-friendly name for it.
