I am using Revit API to create a set of rebar for a beam. By default, when I change the layout rule (using Revit API as well as end user UI), no matter where I place my rebars, they will automatically adjust to spread out the entire face of the host (in this case, the top face of the beam).
However, I want to control the area that my rebars will be laid out so that they only cover a small part but not the entire face of the host when I change rebar layout rule (using Revit API). If I using the end user UI, I can manually grab the handle at the edge of rebar set then adjust the laid out-area after changing layout rule.
Please take a look at the images for better understanding.
I intend to switch from "single" rule (default) to "fixed number" rule. How can I do this? In the worst scenario, I can use "single" rule and place each of the rebar at the desire place, though.
