Connector.Id
Connector.Id
studio-a-int
Connector.Id
studio-a-int
Is there a way to reassign a new Id value of an existing Connector in a Revit Family?
The API expose just:
public int Id { get; }
which obvious will not allow to reassign the Id.
In one of the applications we developed, enumerating the Connectors Ids resulted in Cable Tray Fittings Tees Connectors with Ids: 1, 4 and 5 (we were expecting 1, 2 and 3 for a Tee).
We developed other methods to address our application needs, but I was wondering if there is a way to reassign the Id value once the Connector is created.
Thank you for your suggestions!
jnyp
If I recall correctly there is not a way to assign the id. They are created sequentially and are unique in each family. In order to renumber them you would have to re-create the family and only create the connectors in the order you want them to appear by id.
