Connect transition to another fitting and force it to regenerate
adam.krug
adam.krug
I have a 50 mm x 110 mm transition, 40 mm elbow and 110 mm pipe. When I connect all with
connector.ConnectTo(anotherConnector)
Everything gets connected but the trouble is that the transition family won't regenerate until I e.g. manually drag a pipe a little bit, only then it changes to 40 x 110 mm transition.
Is there any simple way to achieve the regeration via API?
PS:
doc.Regenerate()
won't do the job
I know I could instead delete my transition and create a new one using
Document.NewTransitionFitting()
 but I hoped I could skip such a hassle.
ricaun
Hello @adam.krug
Only using the ConnectTo does not make Revit create the Elbow you need create between the 2 connectors.
Using the NewElbowFitting method. Something like this:
document.Create.NewElbowFitting(connector, anotherConnector);
This gonna force Revit to create the Elbow.
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
adam.krug
hello @ricaun ,
I want to connect and regenerate/recalculate an existing transition... With existing bend on one side, and existing pipe on another side.
ricaun
I miss understood what you mean with the method NewTransitionFitting.
I believe is not possible to regenerate the document with the two connectors connected and make the Fitting appear automatically.
You need to use the Fitting methods. I supposed this gonna work.
document.Create.NewTransitionFitting(connector, anotherConnector);
See yaa
Kevin.Lawson.PE
Yes, this was my finding as well.  You have to manually place the transition.  Get the midpoint between the two connectors you are trying to transition to/from, place a transition there, align the connectors, then connect.
-Kevin Lawson, PE
www.rippleengineeringsoftware.com
Revit heating and cooling load calculations in one click!
adam.krug
that's not good news but thanks @Kevin.Lawson.PE  & @ricaun  .
