Connect Pipe
Connect Pipe
Connect Pipe
I want to connect automatically from pipe 2 to pipe 1 to use the Tee fitting in the Revit Api.
Help me..
The image below:
Thanks & Regards
jeremy_tammik
One way to achieve this is to insert the tee fitting family instance in the required position and then connect the three pipes to its connectors:
Hi
Thank you.. But can I use Trim/Extend function of Revit in Revit APi ?
Thanks & Regards
jeremy_tammik
When you connect as pipe to a fitting, it will adjust its length automatically.
