Conditional breakpoint can't be set
AGGilliam
AGGilliam
I'm trying to set a breakpoint that checks for a couple of element ids as integers, but now in VisualStudio 2022 it throws an error that the metadata for RevitAPI is invalid. I've tried looking into this and I can only find mention of turning on a compatibility mode which is no longer an option. Any thoughts on what the root issue might be? I've tried cleaning, rebuilding, closing and re-opening, updating, and still getting the same error:
caroline.gitonga
Hi @AGGilliam ,
Looks like a similar case has been submitted before on the Forum. You may follow the below forum discussion below to see if you can get any insights on the situation.
https://forums.autodesk.com/t5/revit-api-forum/visual-studio-2015-and-net-4-6-1-debugging-problem/td...
Let me know if this helps.
Carol Gitonga, Developer Advocacy and Support, ADN Open
AGGilliam
In that post the solution was to use the Managed Compatibility Mode, which no longer exists. They also mentioned a Module window but I don't have that either.
RPTHOMAS108
I always find conditional breakpoints a bit hit and miss....
I usually just write an 'if' statement in actual code for the condition and put a breakpoint in the middle of it, then I just comment it out. Do you use copy local? That is the other common thing mentioned (not to use it) when it comes to the unknown issues.
AGGilliam
There were a few things set to copy local by default, I set everything to not copy local but I didn't notice a difference. Adding an if statement would work, it's just nice to be able to add/modify a breakpoint rather than recompiling and restarting Revit.
RPTHOMAS108
You don't have to restart Revit you can usually get away with hot reload button.
I find the hot reload button works for most simple changes. Some things you need to restart anyway i.e. if you add using statements or change method signatures etc.
AGGilliam
I still need to do some more research on the hot reload button. I tried using it after making a couple changes and it errored out so I ended up restarting Revit anyway. I'm not sure if there was some sort of set up I missed or if there are just certain scenarios where it doesn't work. It's good to know that it works though, I was looking forward to using it
