Compile - Edit - test cycle
Is there anyway to reload a program into Revit? I mean, after you have loaded it and executed it, Visual Studiowon't overwrite the .dll file becuase it is still in-use by Revit. When writing a program in C sharp, and then testing it in Revit, it seems like it takes an awful long time to start revit every time you want to test out the smallest change to your program. The development cycle must be easier than this.
Amen.
In addition, and I think this is very important, this makes the learning process very long and difficult. I keep on riding my VBA horse, where I can write, pause, watch object properties and change my code during run-time. Learning an API and being productive at the same time is very easy that way. My experience with Revit's "compile and hope for the best" approach has been frustrating to say the least.
I would be interested to know, how many of the ACAD or Revit API coders are actually trained programmers (compared to a self-taught hack like myself) - because the Revit API seams to almost require that.
Best regards,
Gregor
Look at the "Edit and Continue" section of Visual Studio Help.
It needs to be enabled through the Tools - Options dialog - scroll down to
the Debugging section. Then provided you have hit a breakpoint, you should
be able to change your code and it will rebuild itself when you try to
continue. Exceptions to this are listed in the Help section I think.
As your for second point - I am a full-time programmer, and this is one of
the things you pick up over the years rather than being trained in. Also you
should be able to watch object properties in the debugger - look in the
Debug - Windows menu.
Regards
David
wrote in message news:5408398@discussion.autodesk.com...
Amen.
Best regards,
Gregor
That is great advice. Thanks a lot. I believe the "edit and continue" is enabled by default (at least it was on my machine).
For some reason I never managed to get the debugging to work in the first place. When I start a debug session following all the "use external program" instructions from the revit API documentation, I get an error in the winmain.cpp (attached screen shot).
Any ideas?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
