Committing Transactions when creating a large number of Elements
ewano
Message 1 of 15
ewano
Hi All,
I am just wondering if there is a Transaction limit when it comes to the number of Revit elements that can be created via the API.
I am using Dynamo Python to create,
collect = Autodesk.Revit.Creation.FamilyInstanceCreationData
and use it with the,
items = doc.Create.NewFamilyInstances2(collect)
with the purpose of placing approximately 10,000 Revit families (the family size is 1mb)
Code below:
## Import Reference Examples
import clr
clr.AddReference('RevitAPI')
import Autodesk
from Autodesk.Revit.DB import *
from Autodesk.Revit.DB.Structure import *
clr.AddReference('RevitServices')
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
clr.AddReference('RevitAPIUI')
from  Autodesk.Revit.UI import *
clr.AddReference("RevitNodes")
import Revit
clr.ImportExtensions(Revit.GeometryConversion)
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
clr.AddReference('System')
from System.Collections.Generic import List as sList
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import *
def flat(lst):
	return DSCore.List.Flatten(lst,2)
## Split list into chuncks
def chunks(data,sizes):
	it = iter(data)
	return [[next(it) for _ in range(size)] for size in sizes]
doc = DocumentManager.Instance.CurrentDBDocument
uiapp = DocumentManager.Instance.CurrentUIApplication
app = uiapp.Application
uidoc = uiapp.ActiveUIDocument
location_list = flat(IN[0])
family_list = flat(IN[1])
rotation_list = flat(IN[2])
lev_list = flat(IN[3])
result = []
collect = sList[Autodesk.Revit.Creation.FamilyInstanceCreationData]()
for location, family, rotation, lev in  zip(location_list,family_list,rotation_list,lev_list):
	location1 = location.ToXyz()
	family1 = UnwrapElement(family)
	rotation1 = Math.DegreesToRadians(rotation)
	lev1 = UnwrapElement(lev)
	create = Autodesk.Revit.Creation.FamilyInstanceCreationData(location1,family1,lev1,StructuralType.NonStructural)
	create.RotateAngle = rotation1
	create.Axis = Line.ByStartPointDirectionLength(location,Vector.ZAxis(),1).ToRevitType()
	collect.Add(create)
# Start
TransactionManager.Instance.EnsureInTransaction(doc)
# Stop
TransactionManager.Instance.TransactionTaskDone()
elems = []
for i in items:
	elems.append(doc.GetElement(i))
counts = IN[4]
collect.Clear()
OUT = chunks(elems,counts)
I know this code works to place 100 Revit Families, but my current test is taking a very long time to do 10,000 ish.
Revit has been displaying the 'Committing Transaction' message in the bottom task bar for 10 hours now. The process of creating 100 Revit Families takes approximately 6 minutes, so I am wondering if there is a limit to the number of Revit Elements that can be rolled into being created in 1 Transaction within the API.
Any thoughts or advice?
I guess I could split the creation data into chunks of 100 and commit for each chunk...
Cheers,
Ewan
Cheers,
Ewan
Autodesk ITF 2018-2020 / Senior Project Drafter / Technical & Computational Modelling Specialist / Dynamo Enthusiast
Replies (14)
Message 2 of 15
ricaun
100 families equal to 6 minutes, which looks terrible 😥
I'm not sure if has a limit of elements or changes in the document when committing a transaction.
Pretty sure that does not scale well, with 1000 families you gonna have 1h for sure, and so on.
After the commit, the document is Regenerated and if you add a Transaction for each one probably you gonna have a bigger time.
Your family size looks normal but I supposed a smaller family gonna be faster (Need to make some tests to make sure.)
Make some chunks like you said, every 100 families commit the transaction and notify the user. If was C# I gonna say to use a simple progress bar, but in dynamo, I don't know if that is similar.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 3 of 15
Mert_Yacan
I would try using the NewFamilyInstance function instead of NewFamilyInstance2. I would also do the creation inside the for loop you have, instead of filling the data from one list into another list.
Message 4 of 15
ewano
Thanks for the thoughts @ricaun
The 6 minute runtime also took into account the setting of a multitude of parameter values after the families had been placed, and was a vast improvement on the previous workflow timing.
I have just re-executed the code without the Transaction, to assess exactly how many Revit Families were going to be placed. 28,215, so a little over the 10,000 I thought 😅
I will go look at splitting the creation process to run over 100 elements per Transaction for a sample set of 500 elements, just to start to assess if that is even an option for making progress. And as part of that, change the family type to a simple testing container with limited geometric and parametric data.
Will post back on how I get on 🤞
Cheers,
Ewan
Message 5 of 15
ewano
@Mert_Yacan Also good points, will have a look after I try a sample set run.
Cheers,
Ewan
Message 6 of 15
ewano
100 Simple data container families (3d boxes about 200mm sq with some parameters, not set)
  • 3 min 30 seconds using the NewFamilyInstances2 method outside of the loop with a list of combined CreationData.
  •  2 min  55 seconds using the NewFamilyInstances2 method outside of the loop with individual CreationData.
I have remembered why I needed to use this method (instead of NewFamilyInstance) and it was because of the ability to set the rotation and axis as part of the creation process, and not have to adjust it after, which I think I did test and was very time intensive.
Cheers,
Ewan
Message 7 of 15
ewano
Also looking into the performance timing of rotating placed families after they are created, instead of incorporating this into the creation data. Will post back with some insight on that as well. I've had a Dynamo forum user confirm the method used can create 20,000 elements in about 15 minutes, so something is definitely up with my data. 🤔
Cheers,
Ewan
Message 8 of 15
jeremy_tammik
I have some good news for you as well, to underline the Dynamo forum confirmation:
NewFamilyInstances2 Can Create 27000 Instances
https://thebuildingcoder.typepad.com/blog/2022/08/ifc-property-set-bulk-instances-and-vary-by-group....
Message 9 of 15
ewano
Thanks @jeremy_tammik
This undertaking is part of memory testing for a large automation procedure so finding where the limitations are is key.
I will have a read of your posting in the morning, getting late here...
Cheers,
Ewan
Message 10 of 15
ewano
I performed a quick test this morning to check how the family I am using stacks up against a generic family that only contains a 200mm Cube. I removed my pre-creation code (logic to work out point locations) and used generic points for creation.
Timings as below:
My Family:
Placed 1,000 instances in 30 seconds
Placed 5,000 instances in 13 minutes
200mm Cube:
Placed 1,000 instances in 3 seconds
Placed 5,000 instances in 5 seconds
Placed 10,000 instances in 12 seconds
Placed 50,000 instances in 9 minutes
I have some more batch testing to try splitting my data into 'chunks' for each transaction, and I am hopeful this will help both regeneration and timings. More soon.
Cheers,
Ewan
Message 11 of 15
ewano
I think my family creation time using the FamilyInstances2 method will work overall, I am confident that batch execution using it will work. Just having a head scratcher with the below. Ideally it would run a Transaction for each chunk ignoring any warnings thrown.
Bit of a long one… but here goes.
So Code 1 will process everything as chunks but commit 1 transaction (I’m looking for a transaction per chunk) with no warnings, creates elements as expected. Some DuplicateInstances warnings are created for multiple elements, which is ok as I’m looking on how to ignore this programmatically.
Code 1
import clr
import Autodesk
import Revit
import DSCore
def flat(lst):
counts = IN[4]
	it = iter(data)
chopLen = IN[5]
# Yield successive n-sized chunks from L.
def chop(L, n):
	for i in range(0, len(L), n):
		yield L[i:i+n]
# # Chop Inputs
chopLocation = chop(location_list,chopLen)
chopFamily = chop(family_list,chopLen)
chopRotation = chop(rotation_list,chopLen)
chopLevel = chop(lev_list,chopLen)
#OUT = chopLocation
class DuplicateInstancesWarningSwallower(IFailuresPreprocessor):
    def PreprocessFailures(self, failuresAccessor):
        fail_list = List[FailureMessageAccessor]()
        fail_acc_list = failuresAccessor.GetFailureMessages().GetEnumerator()
        for failure in fail_acc_list:
            failuresAccessor.ResolveFailure(failure)
            failure_id = failure.GetFailureDefinitionId()
            failure_severity = failure.GetSeverity()
            failure_type = BuiltInFailures.InaccurateFailures.DuplicateInstances
            if failure_id == failure_type:
                failuresAccessor.DeleteWarning(failure)
        return FailureProcessingResult.Continue
output = []
result = []
testing = []
for cLocation, cFamily, cRotation, cLev in  zip(chopLocation,chopFamily,chopRotation,chopLevel):
	collect.Clear()
	for location, family, rotation, lev in  zip(cLocation, cFamily, cRotation, cLev):
		collect.Add(create)
	pack = []
	for i in items:
		pack.append(doc.GetElement(i))
	result.append(pack)
OUT = result
Code 2 will process chunks as separate Transactions but throws the DuplicateInstances warnings when run, so not ideal for a ‘hands-free’ user execution. Resolution by the 'OK' button is the option I want to go with.
Code 2
import clr
import Autodesk
import Revit
import DSCore
def flat(lst):
counts = IN[4]
	it = iter(data)
chopLen = IN[5]
def chop(L, n):
		yield L[i:i+n]
# # Chop Inputs
#OUT = chopLocation
output = []
result = []
testing = []
	collect.Clear()
	TransactionManager.Instance.ForceCloseTransaction()
	t = Transaction(doc, "Batch Create Families")
	# Start
	t.Start()
	#tOpt = t.GetFailureHandlingOptions()
	#tOpt.SetFailuresPreprocessor(DuplicateInstancesWarningSwallower())
	#t.SetFailureHandlingOptions(tOpt)
		collect.Add(create)
	pack = []
	for i in items:
	result.append(pack)
	t.Commit()
OUT = result
And Code 3 enables FailurePreProcessor methods, shows no warning but creates nothing…
Code 3
import clr
import Autodesk
import Revit
import DSCore
def flat(lst):
counts = IN[4]
	it = iter(data)
chopLen = IN[5]
def chop(L, n):
		yield L[i:i+n]
# # Chop Inputs
#OUT = chopLocation
output = []
result = []
testing = []
	collect.Clear()
	# Start
	t.Start()
		collect.Add(create)
	pack = []
	for i in items:
	result.append(pack)
	t.Commit()
OUT = result
At least I am making progress
Cheers,
Ewan
Message 12 of 15
ewano
Well testing is going OK. 120 data chunks (100 individual CreationData elements in each)  resulted in 3692 elements being placed in 162 minutes. 😬
That was 120 separate transactions though. @jeremy_tammik Is there a guide limit on the number of transactions that should be committed before performance is affected? Should these be bundled into a TransactionGroup and if so, what are the performance benefits really going to be?
Still looking into saving all pre-creation data to JSON to enable smaller sequential creation runs and better cross process data usage.
I now know once the function has run, the file should auto-save if all commits are successful, instead of regenerating the view (which is what I have just done am still waiting for Revit to unfreeze) 😅
Cheers,
Ewan
Message 13 of 15
jeremy_tammik
Congratulations on making good progress!
I am afraid I cannot provide much guidance here; I think you are at the forefront of research in this area now.
I believe the answers to your questions are unknown, or depend so heavily on the implementation details that they vary from case to case. I suggest benchmarking, researching, and would be very grateful to hear your results.
I am not aware of any.
> Should these be bundled into a TransactionGroup?
Add-ins often do. Probably more for clarify's sake than performance.
> What are the performance benefits really going to be?
Unknown, possibly nil.
Yes, that sounds like a good idea.
Very interesting.
I would recommend maintaining a detailed log of the process as it proceeds to help keep track of where you are. Also, monitor the Revit process health from outside, e.g., by checking that the log file is being updated. If Revit crashes, handle that gracefully and implement a possibility to restart and continue processing at the last known point.
The Building Coder occasionally mentioned some aspects of batch processing that might be of interest:
Message 14 of 15
ewano
"I think you are at the forefront of research in this area now."
Good to know 😅
An update on testing. It would appear from large scale testing that Revit holding lots of Transactions in the 'Undo' stack may be causing a significant decrease in performance. Reducing these through TransactionGroups was something I wanted to try.
I have used a sample Transaction of placing a single Point based Foundation Pad element to compare whether using TransactionGroups provides any performance gains.
Result 1 - Small Scale:
10 Individual Transactions = 7.3 seconds
1 TransactionGroup  containing the same 10 Transactions = 1.4 seconds
This trend of improving the runtime is mirrored in larger scale testing.
Result 2 - Large Scale:
10 Transactions each creating 100 elements = 202 seconds
1 TransactionGroup containing 10 Transactions, each creating 100 elements = 44 seconds
Result 3 - Larger Scale in Project:
I tested again inside my project environment with good results.
Yesterday = 1200 CreationData entries, 3692 Revit elements created, 160 minutes.
Today = 8000 CreationData entries, 8336 Revit Elements created, 160 seconds...
I'm doing something right 😎
I have also implemented an IFailuresPreprocessor, that now works properly to ignore/remove the 'DuplicateInstances' warning. So less warnings for Revit to keep track of as well.
Revit is performing much better now after the entire creation process has completed. So I am happy with that. 🙂
More soon 👍
Cheers,
Ewan
Message 15 of 15
ewano
Hi All,
I have found a solution that I am happy with. 😃
Using a Transaction Group to process groups of 100 Creation data elements as 'SubTransactions' then Assimilating them for a single commit.
Each SubTransaction takes 1.1 seconds to process based on what the Revit Journal File is telling me. 🤔
This timing scales fine for my application, as I have fixed the duplicate element errors that were occurring at this stage in my process.
Doc.Regeneration takes a little while after my process has been run, but I cannot see a way of reducing that time.
(Not that its too long, only takes a couple of minutes after the process 'says' it has been completed in my log file.)
Here is the code for reference, thanks all for your input.
import clr
import Autodesk
from Autodesk.Revit.UI.Events import DialogBoxShowingEventArgs
import Revit
import DSCore
def flat(lst):
counts = IN[4]
	it = iter(data)
chopLen = IN[5]
def chop(L, n):
		yield L[i:i+n]
# # Chop Inputs
# Failure Info
class CreateFailureAdvancedHandler(IFailuresPreprocessor):
		failMessages = failuresAccessor.GetFailureMessages()
		if failMessages.Count == 0:
		if failuresAccessor.GetSeverity() == FailureSeverity.Warning:
			for currentMessage in failMessages:
				failuresAccessor.DeleteWarning(currentMessage)
# Outputs
result = []
testing = []
# Family Instance Creation Data
tg = TransactionGroup(doc,"Multiple Family Creation")
tg.Start()
	collect.Clear()
	# Start the sub-transaction
	t = Transaction(doc, "SubTransaction")
	t.Start()
	# Set how Failures will be handled fore the Transaction
	failureOptions = t.GetFailureHandlingOptions()
	failureOptions.SetFailuresPreprocessor(CreateFailureAdvancedHandler())
	t.SetFailureHandlingOptions(failureOptions)
		collect.Add(create)
	# Place DB FamilyInstances
	# Commit Transaction
	t.Commit()
	# Get Revit Families
	pack = []
	for i in items:
	result.append(pack)
# Combine all the SubTransactions into one Undo Stack item
tg.Assimilate()
## Post Process Flattened Lists to match input structure
resultF = flat(result)
output = chunks(resultF,counts)
OUT = output
Cheers,
Ewan
