CommandData not decalred
' Created by SharpDevelop.
' User: scr4295
' Date: 05/04/2016
' Time: 11:55 AM
' To change this template use Tools | Options | Coding | Edit Standard Headers.
Imports System
Imports Autodesk.Revit.UI
Imports Autodesk.Revit.DB
Imports Autodesk.Revit.UI.Selection
Imports System.Collections.Generic
Imports System.Linq
<Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
<Autodesk.Revit.DB.Macros.AddInId("A4F72B1C-A988-4504-AC48-EEF580842040")> _
Partial Public Class ThisDocument : IExternalCommand
    Private Sub Module_Startup(ByVal sender As ObjectByVal e As System.EventArgs) Handles Me.Startup
    End Sub
    Private Sub Module_Shutdown(ByVal sender As ObjectByVal e As System.EventArgs) Handles Me.Shutdown
    End Sub
    Public Sub File_Name()
        TaskDialog.Show ("Hellow World", "My Message to the World")
        Dim doc As Document = commandData.Application.ActiveUIDocument.Document
     I am getting an error here on commandData like command is not declared, it may be inaccessible due to its protection level.
     can any one tell me where is the mistake.
    End Sub
End Class
Mustafa.Salaheldin
Replace this line:
with:
Dim doc As Document = Me.Document
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Charles.Piro
CommandData is for ExternalCommand (develop with VisualStudio for exemple).
With Macro, use just :
For application Macro :
Document doc = ActiveUIDocument.Document;
For Project Macro :
Document doc = Document;
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
