combo box default value
solvedplus
solvedplus
Dears
good afternoon, i hope you all are fine
i have a working fine API plugin on Revit 2016
when i move it to Revit 2019, combo boxes not showing the default value and selectedindex="0" property not working at all, this was working fine on revit 2016 with the same code
i'm using WPF with MVVM methodes, visual studio 2015 & .NET Framework 4.7.2
kindly did any one face this problem, and how can i force my plugin to read the first value and show it in the combobox
thanks in advance
BIM.Frankliang
Dear Friend,
         You could use below codes:
public ObservableCollection<string> DataList {get;set;}
private string _selectedData ;
public string SelectedData
    get { return _selectedData ; }
    set
        SetProperty(ref _selectedData , value, () => SelectedData );
public ViewModel()
    DataList = new ObservableCollection<string>(list);
    SelectedData = DataList.FirstOrDefault();
Wish it could helpful for you 🙂
Best Regards
Frank Liang
solvedplus
its not working
he refused to assign it in the constrictor
but you some home gave the solution
i create anther list in the combo list property then before return the value , i have assigned the selected item
but its too weird , my code was working fine in old version of revit
what have changed in revit to change its behavior like that
revit ignores the selectedindex property of the combobox
any way many thanks for your response
thanks
public IList<string> optionsList
     get
           IList<string> temp = myList;
           SelectedOption = temp.FirstOrDefault();
           return temp;
