column base offset parameter retrieves null
khalidfathyuar
khalidfathyuar
i have an error when i'm trying to get the column base offset instance parameter it gives me error i tried to use built in parameter Enum and i tried to use look up parameter and both give me error although the storage type is double as i checked in revit look up tool   as iam trying to give it offset
foreach (var columnid in columnsid)
Element column =Doc.GetElement(columnid);
var parameterbaseoffset =
column.LookupParameter("Base Offset").AsDouble();
//parameterbaseoofset.Set(offset);
@jeremytammik
@mikako_harada
@didik.achmadiSQCG4
@vincebohner
RPTHOMAS108
You should avoid using LookupParameter for parameters that are built-in or shared since the name of the parameter alone does not distinguish it.
In your case you can use:
BuiltInParameter.FAMILY_BASE_LEVEL_OFFSET_PARAM
There is another one of the same name called:
SCHEDULE_BASE_LEVEL_OFFSET_PARAM
khalidfathyuar
Thank you it works now@RPTHOMAS108
