Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Collect detail items inside crop region
3 REPLIES 3
mr.engineer.aec
248 Views, 3 Replies
 Hi mate,
 I have many detail items outside crop region.
 But i only want to select detail items inside crop region.
 I use code like this but it collect both inside and outside detail items.
 What can i do ?
 Thank in advanced !
            List<FamilyInstance> symbols = new FilteredElementCollector(doc, doc.ActiveView.Id)
                .OfClass(typeof(FamilyInstance))
                .WhereElementIsNotElementType()
                .Where(x => x.Category.Name == "Detail Items")
                .Where(x => x.IsHidden(doc.ActiveView) == false)
                .Cast<FamilyInstance>()
                .ToList();
3 REPLIES 3
Hi @mr.engineer.aec ,
One solution is to get the bounding box from the crop box and create a BoundingBoxIntersectsFilter.
if(doc.ActiveView.CropBoxVisible && doc.ActiveView.CropBoxActive)
                      BoundingBoxXYZ bb = doc.ActiveView.CropBox;
                      Outline myOutLn = new Outline(bb.Min, bb.Max);
                      BoundingBoxIntersectsFilter filter = new BoundingBoxIntersectsFilter(myOutLn);
Now use this BoundingBoxIntersectsFilter along with other filters in FilteredElementCollector to get the required elements.
Could you please try this suggestion and let me know?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
 Thank @naveen.kumar.t for reply,
 I think if use boundingbox it'll collect detail items like this so,
 I want to collect only inside mate.
Could you please try using BoundingBoxIsInsideFilter.
https://www.revitapidocs.com/2023/eb8735d7-28fc-379d-9de9-1e02326851f5.htm
Naveen Kumar T
Forma Design Contest
Rail Community
