Code reference for Title Block
Hi
I need to do code for title block.I am new to Revit API.Any help will be approciated.
Thanks in Advance.
rosalesduquej
Hi Nimesh,
The best way in order to solve this would be to go over our Revit API training material. Once you become more related to it you could get back to us for further help in case you still need our help. I'm adding you here links to material to get you started with development using the Revit API and also some resources on blogs that are very key to a successful API development. Wish you the best and Happy coding.
Revit API getting started.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975
Jeremy Tammik's Blog
http://thebuildingcoder.typepad.com/
ADN DevTech Blog
http://adndevblog.typepad.com/aec/
I hope you find this very helpful.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Hi
Thanks for the help 🙂
I need to know certain things regarding Autodesk.
Can I use Plug-in created using Revit API in AutoCAD?
Is there any way I can create GUI based plug-in in AutoCAD (Not command
based)
*Nimesh Patel*
