Good day, get the parameters of the concrete elements and assign it to all the bars that are housed in it, the code I have works, however it takes its time to load, I get the impression that there are other ways to do it so that I consume less resources. I appreciate your help, thank you.
namespace RebarParameters
class Parametros
//Instancio a Longitu de Rebar
LongitudRebar longitudRebar = new LongitudRebar();
//Devuelve Parametro compartido
public Parameter Parameter(Element e, String guid)
Guid parameterShared = new Guid(guid);
Parameter parameter = e.get_Parameter(parameterShared);
return parameter;
public Parameter Parameter(Element e, String lookParameter,Boolean boolean)
Parameter parameter = e.LookupParameter(lookParameter);
return parameter;
//Devuelve Parametro BuiltInParameter
public Parameter Parameter(Element e, BuiltInParameter parameterBuild)
Parameter parameter = e.get_Parameter(parameterBuild);
return parameter;
//Devuelve Parametro de tipo BuiltInParameter
public Parameter Parameter(ElementType et, BuiltInParameter parameterBuild)
Parameter parameter = et.get_Parameter(parameterBuild);
return parameter;
//Devuelve parametro Double 0 si existe error
public Double ConvertirDouble(Parameter parameter)
Double dimension;
try
dimension = parameter.AsDouble();
catch (Exception)
dimension = 0;
return dimension;
public void GetSetParameterRebar(List<Element> listHost, Document doc)
//Metodo parametros
foreach (Element el in listHost)
//Parametro de Host
ElementType HostType = doc.GetElement(el.GetTypeId()) as ElementType;
Parameter HostTypeComments = Parameter(HostType, BuiltInParameter.ALL_MODEL_TYPE_COMMENTS);
Parameter HostMark = Parameter(el, "1411f266-da7a-4faa-beb9-3848e3304161");
Parameter QC_HostSector = Parameter(el, "0818baf0-dce1-4ea4-84ac-2f69fae50a84");
Parameter QC_HostNivel = Parameter(el, "d25405d0-37af-43c2-be2d-7efc1c792fcc");
Parameter QC_HostEje = Parameter(el, "2ee543a4-ec44-472e-80c4-520883abe8c0");
Parameter QC_HostFamilia = Parameter(el, "8ca45e69-853c-4132-9452-8124c3b0f3ef");
//rebar in host
IList<Rebar> rebar = RebarHostData.GetRebarHostData(el).GetRebarsInHost();
if (rebar.Count != 0)
// para cada rebar segun su host
List<String> formas = new List<string>();
foreach (Rebar r in rebar)
//Parametros Rebar de Ubicacion y Sectorización
Parameter partition = Parameter(r, BuiltInParameter.NUMBER_PARTITION_PARAM);
Parameter QC_HostMark = Parameter(r, "3be2f711-4769-463b-bda8-39ba39aa578d");
Parameter QC_Sector = Parameter(r, "0818baf0-dce1-4ea4-84ac-2f69fae50a84");
Parameter QC_Nivel = Parameter(r, "d25405d0-37af-43c2-be2d-7efc1c792fcc");
Parameter QC_Eje = Parameter(r, "2ee543a4-ec44-472e-80c4-520883abe8c0");
Parameter QC_Familia = Parameter(r, "8ca45e69-853c-4132-9452-8124c3b0f3ef");
//Parametros de Dimensiones
Parameter ParQC_RebarLength = Parameter(r, "8acbe253-9336-4934-925d-7e2dff0be89d");
Parameter ParA = Parameter(r, "A", true);
Parameter ParB = Parameter(r, "B", true);
Parameter ParC = Parameter(r, "C", true);
Parameter ParD = Parameter(r, "D", true);
Parameter ParE = Parameter(r, "E", true);
Parameter ParF = Parameter(r, "F", true);
Parameter ParG = Parameter(r, "G", true);
Parameter ParH = Parameter(r, "H", true);
Parameter ParI = Parameter(r, "I", true);
Parameter ParAlfa = Parameter(r, "fb540c64-8611-416a-9172-681a1847112d");
Parameter ParBeta = Parameter(r, "b4aa2db2-c434-4457-88a0-f097a6efd159");
Parameter ParGamma = Parameter(r, "da72b204-3415-4298-bc87-3c07fb7b8ce4");
Parameter ParQC_Codigo_Forma = Parameter(r, "f1fb3a75-4c81-4cd7-980d-7cc02d561a6c");
//definicion de parametros de longitud
String QC_Codigo_Forma = ParQC_Codigo_Forma.AsString();
Double a = ConvertirDouble(ParA);
Double b = ConvertirDouble(ParB);
Double c = ConvertirDouble(ParC);
Double d = ConvertirDouble(ParD);
Double e = ConvertirDouble(ParE);
Double f = ConvertirDouble(ParF);
Double g = ConvertirDouble(ParG);
Double h = ConvertirDouble(ParH);
Double i = ConvertirDouble(ParI);
Double alfa = ConvertirDouble(ParAlfa);
Double beta = ConvertirDouble(ParBeta);
Double gamma = ConvertirDouble(ParGamma);
//Calcula la longitud
Double LongPieza = longitudRebar.LongitudBarra(QC_Codigo_Forma, a, b, c, d, e, f, g, h, i, alfa, beta, gamma);
if (LongPieza == 0)
formas.Add(QC_Codigo_Forma);
using (Transaction t = new Transaction(doc, "Parametros"))
t.Start("Parametros");
//Asignar Parametros a rebar
SetParameter(HostTypeComments, partition);
SetParameter(HostMark, QC_HostMark);
SetParameter(QC_HostSector, QC_Sector);
SetParameter(QC_HostNivel, QC_Nivel);
SetParameter(QC_HostEje, QC_Eje);
SetParameter(QC_HostFamilia, QC_Familia);
SetParameter(LongPieza, ParQC_RebarLength);
t.Commit();
if (formas.Count != 0)
String infoformas = "No se encuentra registrado el código de la forma: ";
foreach (string f in formas.Distinct())
infoformas += "\n\t" + f;
TaskDialog.Show("QC Ingenieros", infoformas);
else
TaskDialog.Show("QC Ingenieros", "No se ha encontrado ningun elemento de refuerzo en el elemento: " + el.Id.ToString());
private void CounColorNumber(List<Rebar> list)
foreach (Rebar r in list)
private void SetParameter (Parameter HostParameter,Parameter RebarParameter)
try
RebarParameter.Set(HostParameter.AsString());
catch (Exception)
private void SetParameter(Double HostParameter, Parameter RebarParameter)
try
RebarParameter.Set(HostParameter);
catch (Exception)
