Cloud API Sample - Account Guid
revitaddins
revitaddins
Hi all,
Could anyone please confirm if anyone's using the RevitSDK sample "Cloud API Sample"? I am currently confused about what the input for PATTERN should be.
Additionally, is there an alternative way to obtain the Account Guid without using Forge? Thank you!
jeremy_tammik
Pattern is simply a filename pattern, for instance *, to refer to all files in the folder. It is briefly explained in the sample documentation ReadMe_CloudAPISample.rtf.
Forge no longer exists, it is now named Autodesk Platform Services or APS.
You will need some kind of Autodesk Account credentials in order to perform the main task of this sample, upload models to BIM360 Docs. Use the same credentials that you use to access BIM360 Docs.
