Closing UIView Crashes Revit 2019
RickyBell
RickyBell
I close views in previous versions of revit by using UIDocument.GetOpenUIViews() then using the UIView.Close() command.  This seems to be crashing Revit 2019.
Do you recommend another way of dealing with views since the introduction of tabbed windows?
RickyBell
I should clarify a little.  If the code proceeds to open a wpf form after closing a UIView, Revit crashes.  If I isolate just the code that closes the view, it works.  If I isolate the code that opens the wpf form, it works.  I can't do both though.
Any help would be appreciated.  Thanks.
RickyBell
Here's the entire code.  The form is completely bank.
The .ShowDialog() line at the end errors out with "Attempted to read or write protected memory..."
Thanks.
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiApp = commandData.Application;
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            //Access the document
            Document doc = uiDoc.Document;
            Document DbDoc = uiDoc.Document;
            Selection sel = uiDoc.Selection;
            if (uiDoc.ActiveView.Category.Id.IntegerValue == (int)BuiltInCategory.OST_Sheets)
                Autodesk.Revit.DB.View sheet = uiDoc.ActiveView;
                try
                    foreach (ElementId eleId in sel.GetElementIds())
                        List<ElementId> selElements = new List<ElementId>();
                        Autodesk.Revit.DB.Viewport vp = doc.GetElement(eleId) as Autodesk.Revit.DB.Viewport;
                        FilteredElementCollector collector
                          = new FilteredElementCollector(doc)
                            .OfClass(typeof(Autodesk.Revit.DB.View));
                        foreach (Autodesk.Revit.DB.View v in collector)
                            if (vp != null)
                                if (v.Id == vp.ViewId)
                                    uiDoc.ActiveView = v;
                                    FilteredElementCollector fic = new FilteredElementCollector(doc, uiDoc.ActiveView.Id);
                                    foreach (ElementId elId in fic.ToElementIds())
                                        selElements.Add(elId);
                                    uiDoc.ActiveView = sheet;
                                    foreach (Autodesk.Revit.UI.UIView ov in uiDoc.GetOpenUIViews())
                                        if (ov.ViewId == v.Id)
                                            ov.Close(); //Commenting this line out will let the form open
                                            break;
                                    break;
                        if (selElements.Count > 0)
                            sel.SetElementIds(selElements);
                catch (Exception ex)
                    MessageBox.Show(ex.ToString());
            try
                //Open the form
                frmMyForm varForm = new frmMyForm();
                varForm.ShowDialog();
            catch (Exception ex) { MessageBox.Show(ex.Message); }
            return Result.Succeeded;
jeremytammik
Dear Ricky,
Thank you for your report.
Could you please also attach a file containing a complete minimal reproducible case, that I can pass on to the development team for analysis?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
They are not all add-in savvy, so a macro embedded in an RVT file would be best.
Alternatively, the complete Visual Studio solution zipped up and ready to compile would be acceptable.
I tried to create one for you from your sample code, but cannot since the definition of `frmMyForm` is missing.
Thank you.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
RickyBell
Revit 2019.1 Update fixes this issue.  Thanks!
rriggsQXKN6
Your detail here, helped me solve this in v2007 as well.
Here is the snippet of how I worked around the issue - I hope it helps someone else who is running into this problem.
this.Hide();
 foreach (UIView uiv in openUIVs) {
  if (uiv.ViewId == cView.Id) {
   uiv.Close();
   break;
 this.Show();
"this" is my active Form
