close open views
close open views
russ.green
close open views
russ.green
How can I use the API to close open views except the active view?
I can't see how to close a view....
Russ Green
russ.green
or at least just check if a view is open and not active....
Russ Green
ollikat
Hi
Not tried or checked in any way the following.
You could check what happens if you delete the view from the project with Document.Delete() method, because view also derives from Element.
russ.green
you can;t delete an open view.  never mind!
Russ Green
var pCurrView = pDoc.ActiveView;
pUIDoc.RequestViewChange(pCurrView);
var lViews = pUIDoc.GetOpenUIViews();
foreach (var pView in lViews)
    if (pView.ViewId != pCurrView.Id)
        pView.Close();
Where pDoc is your Document and pUIDoc is you UIDocument.  Keep in mind, you can access your Document via the UIDocument
Andekan
UIDocument.GetOpenUIViews Method Gets a list of all open view windows in the Revit user interface, not only the ones in UIDocument so it may return views from other documents and it may happen that some of them have the same id as the one you want to close so you may end closing mopre than one view
