Close Active Project/Document using UIFramework
ricaun
Advisor Advisor
ricaun
For some reason Revit API does not allow to close an ActiveUIDocument, and I know is possible to close using press F4 or PostCommand.Close.
I want to share a different approach using UIFramework reference.
Here is the extension for the UIApplication to enable CloseAllUIDocument and CloseActiveUIDocument.
Basically the code close UI document window and use the event DialogBoxShowing to force to save or not the document if the save popup happens.
Here is a simple Command to close the ActiveUIDocument.
[Transaction(TransactionMode.Manual)]
public class CommandCloseActiveUIDocument : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementSet)
        UIApplication uiapp = commandData.Application;
        uiapp.CloseActiveUIDocument();
        return Result.Succeeded;
To use the extension your project need to have the UIFramework reference, you can add the reference using the packages below.
<PackageReference Include="Revit_All_Main_Versions_API_x64" Version="$(RevitVersion).*" IncludeAssets="build; compile" PrivateAssets="All" />
or
<PackageReference Include="Nice3point.Revit.Api.UIFramework" Version="$(RevitVersion).*"/>
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
nice3point
This should definitely be in the default API, why such restrictions🙈
rhanzlick
Is there a reason you would want to close a UIDocument vs the UIDocument.Document? What’s the nuance/usecase for the former? (Just out of curiosity.)
ricaun
Is not possible to close the active document, the Remarks in the documentation for the Close method mention that.
"The currently active document may not be closed by this function. It can only be closed via Revit's UI."
So if you use OpenAndActivateDocument and need to close the active document the Close method does not work.
UIDocument uidoc = uiapp.OpenAndActivateDocument("Sample.rvt");
uidoc.Document.Close(false); // Fail to close.
Using the extension should work to close the active document using the Revit UI.
K.Calero_Arup
@ricaun  Somehow I tested willy nilly and got this working with your extension methods, although I'm passing commandlinks instead of yes/no in the OnDialogBoxShowing handler. So it can be applied to any dialog right? (https://rvtdocs.com/2025/bde54cc2-a445-8610-0ced-1851f04eea18)
