Close Active Project/Document in REVIT 2016 using c# API
Message 1 of 17
I am trying to close the active project(.rvt)/document in REVIT 2016 using c# API.
It is throwing below errors, I have tried multiple codes but all are throwing different exceptions.
I have added my code to open the document and the code I tried, please go through this and revert back with the solution ASAP.
The code I have written to open the document:
  commandData.Application.OpenAndActivateDocument(@"D:\REVIT\IBG Projects\C12\C12_type C12 for export 12 sep central.rvt");
I tried below codes:
  •   SendKeys.SendWait("^{F4}"); - Not giving any error though not closing the document.
  • var placeholderFile = @"C:\placeholder.rvt";
    var doc = commandData.Application.ActiveUIDocument.Document;
    var file = doc.PathName;
    var docPlaceholder = commandData.Application.OpenAndActivateDocument(placeholderFile);
    doc.Close(false);
    var uidoc = commandData.Application.OpenAndActivateDocument(file);
    docPlaceholder.Document.Close(false);
  • commandData.Application.ActiveUIDocument.SaveAndClose();
I tried code from bellow two links
http://adndevblog.typepad.com/aec/2015/07/revitapi-close-active-document.html
http://thebuildingcoder.typepad.com/blog/2010/10/closing-the-active-document-and-why-not-to.html
Attached the error came on my screen after adding below code.
Please reply ASAP.
Replies (16)
Message 2 of 17
FAIR59
This code seems fine to me.
doc.Close(false);
Getting the error means that the reloading of the document has failed. I suspect you are in a newly created document, that has no PathName assigned yet.
Check the value of the variable  file.
Message 3 of 17
Thanks for the reply.
I am trying the below code.
Giving the same error can you please help me on that.
 public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementsArg)
            commandData.Application.OpenAndActivateDocument(@"D:\REVIT\IBG Projects\C12S\C12S_type C12s for export 12 sep central_old.rvt");
            var placeholderFile = @"D:\REVIT\IBG Projects\C12S\C12S_type C12s for export 12 sep central_old.rvt";
            doc.Close(false);
Message 4 of 17
FAIR59
the filename for the first project is equal to the filename for the placeholder project.
You try to open en close the same file.
Message 5 of 17
bvgarbar
Hi!
Maybe someone has already found this solution to close active document in revit, i don't know)
but I found the following method.
RevitCommandId closeDoc = RevitCommandId.LookupPostableCommandId(PostableCommand.Close);
uiapp.PostCommand(closeDoc);
Bogdan.
Message 6 of 17
jeremytammik
Shared for posterity by The Building Coder:
https://thebuildingcoder.typepad.com/blog/2019/04/close-doc-and-zero-doc-rvtsamples.html#5
Many thank to you, Bogdan!
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 7 of 17
rui.frazao.oliveira
Hi Bogdan,
I have tried your suggestion but nothing happen.
What I am doing wrong?
Thanks & regards,
Rui
Message 8 of 17
bvgarbar
Hi, Rui!
I checked again my method for Revit versions 15, 17 and 20. Everything works.
Please describe your problem in more detail or send your code to take a look at it.
Bogdan.
Message 9 of 17
rui.frazao.oliveira
Hi Bogdan,
I am using Revit 2017 and I have the following code:
        public bool m_Close()
            string ls_source = "RevitAddinServer::m_Close";
            try
                ib_closedByEvent = false;
                //AddinGlobal.ActiveDocument.Close();
                AddinGlobal.uiapp.PostCommand(closeDoc);
                ib_closedByEvent = true;
                return true;
            catch (Exception ex)
                System.Windows.MessageBox.Show(ls_source + "\n" + ex.Message, "e-grou Message", System.Windows.MessageBoxButton.OK, System.Windows.MessageBoxImage.Error);
                return false;
And I call it from a button in my custom ribbon bar, after open a document and the document is not closed.
If I click more than once appears the message:
"Revit does not support more than one command are posted."
Thanks & Regards,
Rui
Message 10 of 17
bvgarbar
Hi, Rui!
I find it difficult to understand the part of the code that is taken out of context.
If possible, please post your solution.
Bogdan.
Message 11 of 17
rui.frazao.oliveira
Hi Bogdan,
in attach a sample code project with my code.
Thanks & Regards,
Rui
Message 12 of 17
bvgarbar
Hi, Rui.
I looked at your code.
Please tell me what you want to do?
Do you want to make a button on the panel and when clicked, the project should close...or smth else?
Bogdan.
Message 13 of 17
rui.frazao.oliveira
Yes, I want to have a button on the panel and when clicked, "do something"... and at the end of that "something" the active document should close.
At my sample code I ignored the part "do something" (that I already control) and just tried to close the active document (the part that I didn't know how to do).
PS: I have similar addins in AutoCAD and Inventor, and in both I have always ways in API to close the active document by API, but unhappily in Revit the method "ActiveDocument.Close()" don't work as expected.
Thanks & Regards,
Rui
Message 14 of 17
bvgarbar
Hi, Rui!
I tried my solution again using ExternalCommand and IExternalEvent.
Yesterday, I uploaded your solution. At the same time, I noticed a strange effect for myself. When I start debug my solution using, the visual studio changes to your code and revit continues to do something, but all is unsuccessful.
I have an assumption that something went wrong with the addition of the panel and the purpose of the button.
As an alternative, I suggest you try using the VCRevitRibbonUtil library to add a panel and button. Next, try implementing through ExternalCommand.
For example, When i've creating my solution, i used IExternalCommand. Smth done and if Result==true, then try post command.
Thanks & Regards,
Bogdan.
Message 15 of 17
rui.frazao.oliveira
Hi Bogdan,
Did you have some sample using the VCRevitRibbonUtil library to add a panel and button?
Thanks & regards,
Rui
Message 16 of 17
bvgarbar
Hi, Rui!
You can see this sample
https://adn-cis.org/legkoe-sozdanie-knopok-na-lente-dlya-vyizova-vneshnix-komand.html).
Thanks & regards,
Bogdan
Message 17 of 17
rui.frazao.oliveira
Hi Bogdan,
Creating the ribbon with
Autodesk.Revit.UI
instead of
Autodesk.Windows
works well!
Thanks & regards,
Rui
