Check intersection between Solid objects
giancarlo.web
giancarlo.web
I tried using
var unionvolume = BooleanOperationsUtils.ExecuteBooleanOperation(solid1, solid2, BooleanOperationsType.Union).Volume
                        if (solid1.Volume < unionvolume)
                            //Do something
but it looks like it somehow merge those two solids even if they are miles away.
BooleanOperationsType.Intersection/Difference doesn't work either since i need even touching solids
is there a solution to this problem?
Also a BoundingBox is not a solution since i may have complex shaped stuff
FAIR59
Using a combination of Intersect and union gives you a pretty good answer. If the solids touch at an edge this will return [not intersecting, not touching]  instead of [touching].
			Solid interSolid = BooleanOperationsUtils.ExecuteBooleanOperation(s1,s2, BooleanOperationsType.Intersect);
			if (Math.Abs( interSolid.Volume)>0.000001)
				TaskDialog.Show("debug", "intersecting");
				return;
			Solid unionSolid = BooleanOperationsUtils.ExecuteBooleanOperation(s1,s2, BooleanOperationsType.Union);
			double dArea = Math.Abs(s1.SurfaceArea+s2.SurfaceArea -unionSolid.SurfaceArea);
			if (dArea< 0.00001 && s1.Edges.Size+s2.Edges.Size == unionSolid.Edges.Size)
				{ TaskDialog.Show("debug","not intersecting, not touching"); }
			else{TaskDialog.Show("debug","touching");}
danielpinheiro860
Very great solution!
Just to contribue with the situation, I've created another kind of analysis based on the above method and its works very well on my workflow, I am just sharing with you below just for the sake of contribution in some way:
Solid unionSolid = BooleanOperationsUtils.ExecuteBooleanOperation(solid1, solid2, BooleanOperationsType.Union);
Solid interSolid = BooleanOperationsUtils.ExecuteBooleanOperation(solid1, solid2, BooleanOperationsType.Intersect);
double sumArea = Math.Round(Math.Abs(solid1.SurfaceArea + solid2.SurfaceArea), 5);
double sumFaces = Math.Abs(solid1.Faces.Size + solid2.Faces.Size);
double unionArea = Math.Round(Math.Abs(unionSolid.SurfaceArea), 5);
double unionFaces = Math.Abs(unionSolid.Faces.Size);
if (sumArea == unionArea && sumFaces == unionFaces && interSolid.Volume < 0.00001){TaskDialog.Show("debug", "not touching, not intersecting");
else if (sumArea > unionArea && sumFaces > unionFaces && interSolid.Volume > 0.00001)  {TaskDialog.Show("debug", "intersecting"); }
else if (sumArea > unionArea && sumFaces > unionFaces && interSolid.Volume < 0.00001) {TaskDialog.Show("debug", "touching");}
