Check if the event is registered or not
NhuTruong_BeyCons
NhuTruong_BeyCons
Hi all, how to check if a registered event will not register or delete the previous registration event to register a new event, if there is no event in the document, register new. Thank you.
jeremytammik
I am not aware of any method to check whether the event has already been registered or not.
You can register it using the `+-` operator and unregister again using `-=`.
I normally keep track of the registration state using a a Boolean variable or by switching some variable between a non-null initialised state and `null`.
Jeremy Tammik
Developer Technical Services
The Building Coder
