check if element is in a group
I have seen the posts on finding the elements in a model group.
I have also noticed that the filtered element collectors will find elements that are inside groups.  (e.g. filter for all walls, and I get walls that are inside groups).
So my question is:
Is there an efficient way to find out if an element is in a model group?
In a model with lots of groups, I am guessing that scanning through all the elements of all groups to find a match would be inefficient.
The related question to this is - can I find groups 'geographically'?  I.e. within a rectangular extent?  I am hoping there is a way short of finding all the elements in the group and checking where they are...
For clarity, here is what I want to be able to do:
Look within an area outline (that's a whole other issue, I know).
Within this area, find a particular type of element (e.g. by family name, etc), which I expect to be in a group.
Make sure the element is in a group and check the name of the group.
Thanks for your help in advance.
Abba
Mustafa.Salaheldin
Please try this code and if it satisfies your needs please mark this reply as an answer:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                UIDocument uidoc = new UIDocument(CachedDoc);
                ISelectionFilter selFilter = new GroupSelectionFilter();
                List<Reference> groupsReference = uidoc.Selection.PickObjects(ObjectType.Element, selFilter, "Select multiple Groups").ToList();
                List<ElementId> groupsIds = new List<ElementId>();
                foreach(Reference r in groupsReference)
                    Element e = CachedDoc.GetElement(r);
                    groupsIds.Add(e.Id);
                FilteredElementCollector elements = new FilteredElementCollector(CachedDoc, CachedDoc.ActiveView.Id);
                elements.OfClass(typeof(FamilyInstance));
                List<FamilyInstance> elementsInGroups = new List<FamilyInstance>();
                StringBuilder sb = new StringBuilder();
                foreach (FamilyInstance inst in elements)
                    ElementId e = inst.GroupId;
                    if (groupsIds.Contains(e)) {
                        elementsInGroups.Add(inst);
                        string groupName = CachedDoc.GetElement(e).Name;
                        sb.AppendLine(string.Format("element: {0} is of group: {1}",inst.Name,groupName));
                TaskDialog.Show("Revit" , sb.ToString());
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        public class GroupSelectionFilter : ISelectionFilter
            public bool AllowElement(Element e)
                return (e.Category.Id.IntegerValue.Equals(
                  (int)BuiltInCategory.OST_IOSModelGroups));
            public bool AllowReference(Reference r, XYZ p)
                return false;
        #endregion
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Thanks, Mustafa,
This makes sends, and it looks like it will work.  The only issue that I can see, is that if I have about a hundred groups, each with quite a few elements, this could start to get slow, if I want to deal with things dynamically.  Maybe I can build an index and then just keep it up to date as things are modified.
I will give it a try and let you know what happens...
I think this wont work for nested groups. The nested group will be a element in the parent group. But the elements in the nested group are not children of the parent group but children of the nested group. I posted somewhere in this forum a snippet to recursivly get all the elements in a model group, containing the elements of nested groups as well.
JimJia
I think Mustafa's code is the solution to find element in group, we can use this method for nested group.
regarding nest group post mentioned by Michal-sk, I guess he means this page:
http://forums.autodesk.com/t5/revit-api/recursive-get-elements-in-group/m-p/6241156/highlight/true#M...
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
