Check if an Element is of Room type?
How to check programmatically if a given Element is of type Room?
matthew_taylor
If TypeOf elem Is DB.Architecture.Room Then
   dim rm as DB.Architecture.Room =trycast (elem, DB.Architecture.Room )
end if
I figure that'll get you where you need to go.
If you're handling a user selection, you could implement an ISelectionFilter filter to limit the selection to just rooms.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
jeremytammik
In addition to Matt's very helpful suggestion (thank you very much, Matt!), please note that the room element cannot be directly used for element filtering.
Use an intermediate spatial element instead:
http://thebuildingcoder.typepad.com/blog/2011/11/accessing-room-data.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Mustafa.Salaheldin
You can filter by category or you can check the category name of the element if it equals Rooms. Please have a look on the following code and if it satisfies your needs mark this reply as an answer.
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RvtTest
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                //TODO: add your code below.
                FilteredElementCollector collector = new FilteredElementCollector(CachedDoc);
                ICollection<Element> rooms = collector.OfCategory(BuiltInCategory.OST_Rooms).ToElements();
                collector.WhereElementIsNotElementType();
                StringBuilder sb = new StringBuilder();
                foreach (Element el in rooms)
                    if (el.Category.Name == "Rooms")
                        //This is a room
                TaskDialog.Show("reavit", sb.ToString());
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        #endregion
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
