Changing revision schedule height
ringzinc
ringzinc
Community Visitor
Community Visitor
Hi all, my first question here and I hope some can point me in the right direction.
Does anyone know how to change the height of a revision schedule on a sheet using Revit API (instead of changing it manually by dragging the blue round control as shown below)?  My revision schedule is currently set to user defined height and I'm trying automate its placement on a sheet.
Thank you for you time!
Ren
caroline.gitonga
Hi @ringzinc
I have not come across such control on schedules. You could go through the Revit idea board on several related cases: https://forums.autodesk.com/t5/revit-ideas/adjustable-row-heights-for-schedules/idi-p/6724062  and see if there could be any workaround that can work for or add comments on the idea for implementation in future releases.
In the meantime, I will forward the case to the engineering team to see  if there is a workaround to achieve the same as we wait for the fellow community members to provide insights.
Carol Gitonga, Developer Advocacy and Support, ADN Open
