I have been working on an addin for Revit 2020 (the same in my previous posts) and now I want to know if there's a way of changing my current code to make viewports with no title and line.
The current code makes 3 viewports in the default style (Title and Line). However, I want a viewport without those elements present.
I want to do this through the API.
Here's the code:
AddViewToSheetCommand.cs:
#region Namespaces
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System;
using System.Collections;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
#endregion
namespace RevitAddin
[Transaction(TransactionMode.Manual)]
class AddViewToSheetCommand : IExternalCommand
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
// Filtered Element Collector list for the 3D Views
List<View3D> all3DViews = new FilteredElementCollector(doc).OfClass(typeof(View3D)).Cast<View3D>().ToList();
all3DViews.OrderBy(a => a.GetTypeId());
// Filtered Element Collector list for Sheet Views
List<ViewSheet> allSheetViews = new FilteredElementCollector(doc).OfClass(typeof(ViewSheet)).Cast<ViewSheet>().ToList();
allSheetViews.OrderBy(b => b.GetTypeId());
// Filtered Element Collector list for created Viewports
List<Viewport> allNewVps = new FilteredElementCollector(doc).OfClass(typeof(Viewport)).Cast<Viewport>().ToList();
allNewVps.OrderBy(c => c.GetTypeId());
// Grab created Sheet View
ViewSheet sheet = allSheetViews.LastOrDefault();
// Grab all created Views
View3D v1 = all3DViews[all3DViews.Count - 3];
View3D v2 = all3DViews[all3DViews.Count - 2];
View3D v3 = all3DViews[all3DViews.Count - 1];
// Modify document within a transaction
using (Transaction tx3 = new Transaction(doc))
tx3.Start("AddViewToSheet");
// Add 3 viewports, 1 for each view
Viewport viewport1 = Viewport.Create(doc, sheet.Id, v1.Id, new XYZ(0.45, 0.45, 0));
Viewport viewport2 = Viewport.Create(doc, sheet.Id, v2.Id, new XYZ(0.45, 0.75, 0));
Viewport viewport3 = Viewport.Create(doc, sheet.Id, v3.Id, new XYZ(1, 0.45, 0));
tx3.Commit();
return Result.Succeeded;
}I have also made available all the code used in this API for testing purposes (Check .zip file bellow)
