Change routing programmatically
Josh.Thomason
Josh.Thomason
I have managed to make an app that rotates stuff and moves stuff thanks to the help on this forum and I really appreciate that. I was trying to make the same code execute on a dockable dialog instead but after weeks of study and research I am giving up on that for now and focusing on figuring out what I want all the buttons to do first. Events, modeless forms, and delegates are too much for me right now. lol
I was hoping someone could tell me if this is possible programmatically. To change a from a tee coming straight off the pipe at the same elevation to coming up and then over.
I know I could make the pipe cute, the tee rotate, and the other pipe raise up. Just not sure if I can make it trim the pipe back together. I appreciate any input. I'm working on an app the ease pipe modeling headaches.
From this
To this
stewart_skyler
You could select the pipe coming out of the tee, and the tee itself, and rotate it about the center of the run using RotateElements, draw in a new pipe for the 90, and then use NewElbowFitting to "trim" the two pipes together.
The Building Coder has an example of the NewElbowFitting method in action here.
Josh.Thomason
Thanks! There has to be a way to combine all of those.
