change Revit application setting?
zhuliyi0
zhuliyi0
Can I change application settings programably?
Specifically, I want to change the settings at the lower right corner of UI:
Accepted solutions (3)
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @zhuliyi0 ,
try using this below link
https://www.revitapidocs.com/2020/12e366b2-1437-3e59-f754-8e141ebbe031.htm
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
zhuliyi0
I tried looking for something in API doc, couldn't find any. I might
missed it somewhere in it?
Sean_Page
As @naveen.kumar.t  mentioned, I believe this is what your looking for.
https://www.revitapidocs.com/2020/b08cf01a-6a3e-4833-8b73-ccf7803f977b.htm
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
franciscopossetto
Hey,
I tested what @naveen.kumar.t  provided you. It is working. Just one detail to mention is that the icons are not updated after modify the properties... until you click one of them from the UI. Then they are updated.
SelectionUIOptions selectionUIOptions = SelectionUIOptions.GetSelectionUIOptions();
selectionUIOptions.SelectLinks = false;
selectionUIOptions.SelectUnderlay = false;
selectionUIOptions.SelectFaces = false;
selectionUIOptions.SelectPinned = false;
selectionUIOptions.DragOnSelection = false;
This is the result after run this code, everything is locked but icons haven't changed.
If I click one of them, it changes and the rest are updated.
Kind regards.
Github:
https://github.com/franpossetto
zhuliyi0
Thanks guys, it worked.
