Change Offset
Change Offset
jainn
Change Offset
jainn
Hi All,
Please suggest how to set offSet in Pipe before executing PostableCommand Programatically.
Regards
Namit Jain
Aaron.Lu
Pipe.get_Parameter(BuiltInParameter.RBS_OFFSET_PARAM).Set(1.0)
Tips:
always use RevitLookup tool to spy the objects inside Revit, you will know RevitAPI better.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
jainn
Dear Aaron,
Thanks for your reply.
Actually while drawing pipe from revit i am able to change offset(Ex. from 15 to 16). but unable to change create pipe pointer location.
Refer Below Image.
Regards
Namit Jain
jainn
Please suggest.
Regards
Namit Jain
jainn
Dear All,
Please Suggest
Regards
Namit
