Change normal of drafting view plane
Hello everyone, I have a lot of model lines which are all in XZ plane (Y=0). I want to create detail lines in a drafting view from these model lines. However, the drafting view plane is XY plane (Z=0), and my code throws “curves must be in the plane”. I do not want to change my model lines because that needs a lot of modification to my add-in. Is there a way to change the normal of drafting view to other directions? or some other ways to accomplish this? Thanks
jeremytammik
The ViewDrafting SketchPlane property is read-write, so you might be able to change it as you please:
https://www.revitapidocs.com/2020/2531634f-f0d4-3cb3-7f8a-fe809d33a61f.htm
Can you create a drafting view through the user interface that does not lie in the XY plane with Z equal to zero?
If so, you can presumably do so programmatically as well.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy,
Thanks for your reply. I followed your suggestion to set the ViewDrafting SketchPlane property. But it throws an exception. Following is my code:
public static ViewDrafting Create_Drafting_View(Document doc)
            ViewFamilyType viewFamilyType = new FilteredElementCollector(doc)
            .OfClass(typeof(ViewFamilyType)).Cast<ViewFamilyType>()
            .FirstOrDefault(q => q.ViewFamily == ViewFamily.Drafting);
            Transaction trans = new Transaction(doc, "create drafting view");
            trans.Start();
            ViewDrafting draftView = ViewDrafting.Create(doc, viewFamilyType.Id);
            Plane plane = Plane.CreateByNormalAndOrigin(XYZ.BasisY, XYZ.Zero);
            SketchPlane skplane = SketchPlane.Create(doc, plane);
            draftView.SketchPlane = skplane;
            trans.Commit();
            return draftView;
draftView.SketchPlane = skplane throws exception “Model lines can not be drawn in current view”. I guess the error message means the drafting view do not accept model lines and SketchPlane can not be set. I tried to do this manually through UI, but there is no options for setting the plane normal.
jeremytammik
Well, if it can't be done, then it can't be done, can it?
Jeremy Tammik
The Building Coder
Revitalizer
transform the Curves, not the View.
In this very old post you can find a GetTransformToZ method which will help you to rotate your Curves into a XY plane, with an arbitrary Z value
https://thebuildingcoder.typepad.com/blog/2009/03/transform.html
You will also need to translate them from Z to zero to fit the requirements of the ViewDrafting (Which originates in 0/0/0).
For a given Curve, you can get a transformed copy by curve.CreateTransformed(yourTransformation).
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Thanks for the suggestion. I believe the curves can be moved to any direction and place we want, but that will cause a lot of changes to my code. I will just use section view to display the detail curves.
