Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
CF-1201 [Purge unused objects]
4 REPLIES 4
pbuggmen
1091 Views, 4 Replies
Anyone know if this is being looked into?
Tags (3)
4 REPLIES 4
jeremytammik
in reply to: pbuggmen
Dear Phil,
Thank you for your query.
The wish list item CF-1201 [Purge unused objects] is in the database, still open, marked as critical, and I see no activity on it from the development team.
I'll check whether they have any comments on it.
Purging things is requested quite frequently.
Can you check the Revit Idea Station for corresponding entries as well, please and vote for all that match your needs?
I am sure there are some related to this.
Here is the last public mention of this topic on the blog that I see:
http://thebuildingcoder.typepad.com/blog/2017/04/forgefader-ui-lookup-builds-purge-and-room-instance...
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
pbuggmen
in reply to: jeremytammik
I'ts embarrasing to have to provide excuses for creating a cumbersome soln using postcommand for an operation that should be easy to perform with the revit api. I will be the torchbearer for those that wish it included in our tool kit soon!
jeremytammik
Dear Phil,
Thank you for your update and initiative.
Can you check and ensure that this wish is also listed and voted for in the Revit Idea Station?
Thank you!
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
I have found an existing simple solution for this (for Revit 2017+). See my code repository:
https://gitlab.com/MattTaylor/RevitPurgeUnused
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Rail Community
