Cefsharp browser JavaScript Binding not working
Message 1 of 1
Hello Forum,
For the current addin I am developing I have implemented a CefSharp browser inside of a DockableDialog loading a local .html page. Currently I am trying to bind a .Net class and call its functions from the Webpage via JavaScript Binding of CefSharp (https://github.com/cefsharp/cefsharp/issues/2246). But I have run into the following issues:
  • When trying to bind the object via CefSharp.BindObjectAsync() from the Webpage it won't bind the object at all.
  • When trying to bind the object via browser.ExecuteScriptAsync("CefSharp.BindObjectAsync();") it will bind the object but I am unable to call its functions afterwards.
This is the code I have:
  • Binding the object in JS and calling the showMessage function on button click:
function CallAddin()
	(async function()
		console.log("HERE");
		await CefSharp.BindObjectAsync("bound");
		bound.showMessage();
  • Resolve the binding of the object and check if successfully bound in C#:
browser = new ChromiumWebBrowser(); browser.JavascriptObjectRepository.ResolveObject += (sender, e) =>
    var repo = e.ObjectRepository;
    if (e.ObjectName == "bound")
        repo.Register("bound", new Translate(), isAsync: true, options: new BindingOptions());
browser.JavascriptObjectRepository.ObjectBoundInJavascript += (sender, e) =>
    var name = e.ObjectName;
    TaskDialog.Show("Info", "Successfully bound object");
  •  The class to bind to the Webpage:
class Translate
    public void ShowMessage()
        TaskDialog.Show("Info", "This was called from the Webpage");
 I use:
  • Revit2020
  • CefSharp 65.0.1
  • .NET Framework 4.7.2
Cheers
Replies (0)
