Catch errors
Catch errors
Catch errors
Hi there,
I'm trying to switch a profile in a sweep. When the profile is not correctly drawn (like none closed loop or overlapping lines) Revit will throw a messagebox telling the sweep can't be made, with the options Delete or Cancel.
I receive this message when I am doing a transaction.Commit. I have put a try catch around it, but it never comes in the catch.
Does anybody know how you can intercept this error message of revit so I can do a transaction.rollback in case of an incorrectly drawn profile.
Kind regards,
Revitalizer
Hi Remy,
what about your Transaction's FailureHandlingOptions ?
You could implement a IFailuresPreprocessor.
This would give you access to single FailureMessageAccessor objects, which give you more detailed information about what's happened and why.
The IFailuresPreprocessor returns a FailureProcessingResult, so you can rollback your transaction by returning FailureProcessingResult.ProceedWithRollBack.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Why not verify for yourself that the profile is correct before using it?
A few of the Revit classes even provide a validity checking method (view
crop region does I think). If you can't find a built-in method, it is not
too difficult to perform the check yourself by looping through and checking
that each end point is within Revit's geometric tolerance (1×10^-9) of
exactly one other end point.
It is then also a good idea to check that the loopd doesn't self intersect.
Which is a little trickier, but if the loops provided are mostly correct
with just the occaisonal gap then you could probably skip this.
Thank you both for your suggestions. I will try the FailureHanlding method first, because at this time it is enough for me to catch the fact the profile is incorrect. I will let you know the result 🙂
jeremytammik
Hi guys,
Thank you for the helpful suggestions.
One possibility to validate curve loops is provided by the ExporterIFCUtils.ValidateCurveLoops method.
I used it once in the RoomEditorApp:
http://thebuildingcoder.typepad.com/blog/2013/04/extrusion-analyser-and-plan-view-boundaries.html#4
Here is the code, although currently commented out:
https://github.com/jeremytammik/RoomEditorApp/blob/master/RoomEditorApp/CmdUploadRooms.cs
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
