Catch Activating View(port) in a Sheet
mdb
Message 1 of 11
mdb
To update my Dockable Pane to the correct View settings, I should be able to detect which View is active. This works well by capturing the ViewActivated Event, but I did notice that the Event (actually there is no event visible in the Lookup EventMonitor) is not triggered when the View is activated by entering a View(port) in a Sheet.
Is there another way to handle opening a view on a sheet?
Replies (10)
Message 2 of 11
scgq425
Dear mdb
 u can use the iddleing event or documentchanged event to monitor this changed .
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
Message 3 of 11
mdb
Unfortunately, the DocumentChanged Event does not notify you when a Viewport is activated.
I'm going to try it via the Idling Event.
Thanks for the tip!
Message 4 of 11
scgq425
Dear mdb:
thanks for u reply this message , if u have other idea to solve it , u can tell me . and i will try to solve this in my revit version . thanks
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 5 of 11
scgq425
Dear mdb:
u can use the code to mirror view changed ,and usr a local data to recored this changed , u alsa can use mvvm or implention the notification influence to get the change .
`_localId` is the private id.
RevitCommandData.UiApplication.Idling += new EventHandler<IdlingEventArgs>(UiApplicationOnIdling);
private void UiApplicationOnIdling(object sender ,  IdlingEventArgs args)
var uiApp = sender as UIApplication;
var activeViewId = uiApp.ActiveUIDocument.ActiveView.Id;
//var transactionName = string.Concat(args.GetTransactionNames());
if (activeViewId.IntegerValue != _localId.IntegerValue)
_localId = activeViewId;
MessageBox.Show($"Changed id : {_localId}");
//uiApp.Idling -= new EventHandler<IdlingEventArgs>(UiApplicationOnIdling);
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 6 of 11
scgq425
i find a fast api to solve this . the idling is a idea , the current way is use` ViewActivating` which in uiapplication , like this code :
RevitCommandData.UiApplication.ViewActivating += (sender, args) =>
var id = args.CurrentActiveView.Id;
MessageBox.Show($"Changed id : {id}");
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 7 of 11
scgq425
Hi mdb :
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 8 of 11
mdb
Hi @scgq425,
I am already registered for ViewActivated and DocumentChanged, but they do not notify me when I open a Viewport from a sheet.
I also tried the Idling, but immediately I found (which seems a bit logical to me because it keeps checking constantly) that my Revit became laggy when scrolling in the ProjectBrowser.
As a last resort I added a button so i can update the Panel manually.
Message 9 of 11
scgq425
hi mdb:
in my code , can monitor the view changed , u use the mvvm to create dock
pane or not ?
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 10 of 11
mdb
@scgq425
I suspect you are talking about opening a View itself, I already catch this. 😉
I want a notification when a Viewport is opened in a opened Sheet.
Or am I wrong and overlooking something?
Message 11 of 11
scgq425
Hello @mdb  :
in this i understand u put is just view changed , but if u just konw viewport u also can use idling to solve it , if use active the view like a section , the activeViewType is a section type , and u not ,this is a viewsheet type , use this to changed u states.
LanHui Xu 徐兰辉
Blog
LinkedIn
