Cant cast Element to Room
Kevin.Bell
Advisor Advisor
Kevin.Bell
I'm trying to iterate a load of FamilyInstances from a linked model to find out their room locations which I will add to a parameter.
I'm getting the FamilyInstance location point and want to check it using Room.IsPointInRoom, I've collected a list of rooms from the model and linked models as elements.
I now need to cast the Elements to a Room to use the method IsPointInRoom and am trying:
Room thisroom = roomelement as Room
But when I try this I get the error 'Type or Namespace Room cannot be found'.
My code is using :
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
Am I missing something?
Thanks.
RPTHOMAS108
Rooms are within the Autodesk.Revit.DB.Architecture Namespace
Kevin.Bell
Bingo!
Thanks for your help!!
