cannot update parameter value
I tried to update a shared parameter's value using Set() method in my Command. I get the Parameter through its name and set a new value, it should seem very simple but the modification never displays in the property explorer and no error or exception thrown, I've no idea whether the value is changed. I googled a lot and found nothing fix my problem. What I can ensure is:
I set the Transaction Mode to TransactionMode.Automatic
The Document and the Parameter are not read-only when the method executed.
Here's my code snippet, could anyone tell me what's wrong in my code or give me suggestions? Thanks.
        private void OnSave()
            if (!CanSave())
                return;
            Saved = false;
            foreach (var id in EditElmentIds)
                var element = _doc.GetElement(id);
                foreach (var item in ChangedItems)
                    var propertyName = CommonData.CodeParamsDic.FirstOrDefault(t => t.Key == item.Key.ToString()).Value;
                    var param = element.get_parameterByName(propertyName);
                    param?.Set(item.Value);
            MessageBox.Show("Completed!");
            EditElmentIds.Clear();
            ChangedItems.Clear();
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Automatic Transaction Mode is considered obsolete.
Try to set the transactionmode to MANUAL and place your code inside the transaction.
Transaction actrans = new Transaction(doc);
                actrans.Start("Transaction Name");
                //YOUR CODE
                actrans.Commit();
see this link
https://thebuildingcoder.typepad.com/blog/2012/05/read-only-and-automatic-transaction-modes.html
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
