cannot launch revit 2020
asif.shamim
asif.shamim
i installed revit 2020 but i had some problems in dynamo so i unistalled the revit completly but when i tried to install it again it shows the revit 2020 is already installed and it showed some files to download, i dowloaded them but after finishing, i cant find revit 2020. need help
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
