Cannot get rebar number
Hi, I have a problem with obtaining rebar number via Revit API. I can spot Rebar number in Revit Lookup tool, but when I retrieve all of the parameters in API by rebar Parameters property I cant find it there. Any attempt to get its value end with null reference exception. What am I missing?
so-chong
Yes, I did, I know that Rebar number is TextParameter. In my case I'm passing rebar from previous method so I don't need to filter it, the problem is that it rebar number parameter seems to be missing in rebar object.
My work flow looks like this, I create rebar in Revit API, then I want to create rebar container out of those bars. But I also want to put rebar number parameter into one of rebar container parameters, so I look for it... and I'm failing. If I only create bars in Revit API then I'm able to find its rebar number by Revit Lookup, so I'm kind of sure that bar and its number was created properly. Here is the code:
public static Autodesk.Revit.DB.Structure.Rebar CreateRebar(int hostNumberId, XYZ normal, Autodesk.DesignScript.Geometry.PolyCurve polyCurve)
//Some logic here
return rebar;
public static Autodesk.Revit.DB.Structure.RebarContainer CreateContainer(Autodesk.Revit.DB.Structure.Rebar[] rebar,int hostIdNumber)
ParameterSet set = rebar[0].Parameters;
Parameter param = rebar[0].get_Parameter(BuiltInParameter.REBAR_NUMBER);
//Create container etc.
return container;
And here is screenshot showing bars created in RevitAPI:
EDIT: "Numer zbrojenia" means rebar number in polish ;]
I met the matter too.Do you have got the solution?
Not really, but I have made work around. I have changed CreateRebar method output for ElementId, so I'm passing this instead of Rebar, then in CreateContainer I'm looking for rebar number using it's ID. I works that way.
