Cannot find Name of ColorFillSchemeEntry by API
supportT7RUE
Message 1 of 10
supportT7RUE
I'm looking into API to retrieve Color for given Area Type.
Quick search:
var schemes = new Autodesk.Revit.DB.FilteredElementCollector(doc)
.OfCategory(Autodesk.Revit.DB.BuiltInCategory.OST_ColorFillSchema)
.Select(s => s as ColorFillScheme);
var rentable = schemes
.Where(s => s.Name == "Rentable Area")
.FirstOrDefault();
List<ColorFillSchemeEntry> entries = rentable.GetEntries();
If I look on fields of each entry, I can find proper color, but not the name of given Area Type or any index. Entry.Caption or entry.GetStringValue() return empty string.
On GUI I clearly can see which color applies to which type, how can I find this relation by API?
Replies (9)
Message 2 of 10
Sean_Page
It looks like you just need to use .GetStringValue() method.
--Revit Lookup is invaluable--
Sean Page, AIA, NCARB, LEED AP
Senionr Partner, Computational Designer, Architect
Message 3 of 10
Sean_Page
This was quick in Dynamo via Python, but it worked fine.
Make sure you are getting a specific  entry to use the method on and not the list.
string name = entires[0].GetStringValue()
Message 4 of 10
mut9lu
GetStringValue() works for entries of Rooms color scheme, but not for Areas. Elements inside GetEntries() have empty values under GetStringValue(). That was first what I've tried (second after entry.Caption).
Message 5 of 10
Sean_Page
What if you use the ElementId value there to get the element?
Message 6 of 10
mut9lu
Ahhh, it was not element itself, but its GetDependentElements()
Thanks for pointing out RevitLookUp, I heard of it but didn't use previously.
Message 7 of 10
architect.bim
One of the solutions could be getting all unique area types as parameter values of area objects. You can make a dictionary and use it to get proper area type names and colors:
# Python
area_types = {}
for area in FEC(doc).OfCategory(DB.BuiltInCategory.OST_Areas):
    area_type_parameter = area.get_Parameter(DB.BuiltInParameter.AREA_TYPE)
    area_type_id = area_type_parameter.AsElementId()
    area_type_name = area_type_parameter.AsValueString()
    if area_type_id not in area_types:
        area_types[area_type_id] = area_type_name
for scheme in FEC(doc).OfCategory(DB.BuiltInCategory.OST_ColorFillSchema):
    if scheme.Name == 'Rentable Area':
        scheme_entries = scheme.GetEntries()
entry_colors = {}
for entry in scheme_entries:
    entry_name = area_types[entry.GetElementIdValue()]
    if entry_name not in entry_colors:
        entry_colors[entry_name] = entry.Color
Maxim Stepannikov | Architect, BIM Manager, Instructor
Message 8 of 10
architect.bim
Is RevitLookup 2022 already available?
Message 9 of 10
Sean_Page
Officially no, but since R22 has the same .Net version I assumed it would work and manually copied it to the add-ins folder. Works perfect.
Message 10 of 10
architect.bim
Very nice! I'll check it up 😃
