Cann't hide elements
I tried to hide/show element in a view but I got the error message:
"One of the elments cannot be hidden. Parameter name:elementIdSet"
I used this piece of code befor to hide show text on a view but it is not working now. The model contain links also. What is the the wrong in this code:
List<ElementId> allId = new List<ElementId>();
//I add the elementsId in allId
try
view = (Autodesk.Revit.DB.View)doc.ActiveView;
// ss += view.Name + "\n";
MessageBox.Show("View " + view.Name);
catch (Exception ex)
MessageBox.Show("View " + view.Name + " could not reviewed\n");
try
Transaction hide = new Transaction(doc, "Hide the elements");
hide.Start();
if(allId.Count>0)
view.HideElements(allId);
hide.Commit();
MessageBox.Show( "View " + view.Name + "can not be hiden \n"+ex.Message);
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
You have a list of elements.
Use CanBeHidden method to check whether the element can be hidden.
Create one more list and collect those elements which cannot be hidden.
Examine the list and find out which element causes this error.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thank you for the answer. It works
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
If this helped solve your problem please mark it as a solution😁
Naveen Kumar T
