Cancel running command
carolina.machado
carolina.machado
Hello everybody,
Do you know if there is a way to monitor the ESC key to stop an external command execution? Or any other way to do so? I have some commands that takes a long time and I want to enable the users to Cancel the running if they get tired of waiting.
Thanks in advance!
jeremy_tammik
Long duration built-in Revit commands display a progress bar and regularly raise the ProgressChanged event, enabling cancelling the process::
https://www.revitapidocs.com/2024/cabf8932-111c-6036-3d74-3d33c18260ed.htm
Inside your own code, if you are in a loop, you can throw an exception, e.g., OperationCancelled. That should normally terminate the external command. If you wish, you can try to catch it an to display a more graceful message than the normal Revit error report.
carolina.machado
Thank you, @jeremy_tammik . My goal was to enable user to stop an external command though.
I searched a bit more and found this: https://jeremytammik.github.io/tbc/a/1281_progress_animated_gif.htm which led me to this: https://github.com/lotusinriver/MonitorProgressRevit
I think I'll try implement it in my code. Do you know if it stopped working for newer versions of Revit?
