Can you access saved selections via revit api?
DanielKP2Z9V
DanielKP2Z9V
I don't like how Edit Selction dialog won't let you delete multiple "saved selections" in one go and I wanted to create a custom dialog that would, but can't find a way to access saved selections via revit api - is this possible? Saved selections may be known as "selection filters" perhaps?
Please tell me if it's not possible - I will create a Revit Idea then so devs can ignore it further.
I taunted the deepseek demons to solve it, but to no avail.
DanielKP2Z9V
ok, claude AI has done it: https://0x0.st/8KYO.bin looks like it's called "SelectionFilterElement"
just as I was about to give up...
jeremy_tammik
Thank you Daniel for a very nice interesting item and good research. I was previously not aware of the SelectionFilterElement. The sample code in the method documentation is interesting as well. Looking forward to seeing how you are going to use this. Cheers.
DanielKP2Z9V
thank you Jeremy, please see demo below (copy) - I believe it's useful because I couldn't delete multiple saved selections in the default revit dialog in one go, which was slowing me down when creating 8-10 temporary saved selections for a particular task that you wanted to dispose of immediately after
DanielKP2Z9V
by the way I'm still working on a collection of such helper scripts, hopefully will finish writing documentation soon...
