Can We modify revision cloud arc?
dhanait_ajay13
dhanait_ajay13
Using API can modify RevisionCloud Arc shape, size etc.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @dhanait_ajay13 ,
Please take a look at the below link
https://forums.autodesk.com/t5/revit-api-forum/modify-the-arc-size-of-the-revision-cloud/td-p/104342...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
dhanait_ajay13
i see above link but my problem not solved. this create same as default i want change shape, size
naveen.kumar.t
Autodesk Support
Autodesk Support
Did you try this suggestion given by Jeremy?
"If really needed, you might be able to create your own detail curves to represent the revision cloud geometry and hide the original geometry."
Naveen Kumar T
