Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Can't understand how to obtain solids out of a group
DanielKP2Z9V
DanielKP2Z9V
Does anyone have any guides to understand how to get geometry to perform BooleanOperations ?
I have a group of structural framing elements and trying to cut them out of a toposolid. I'm new to Revit API and can't "unpack" the combo: Group -> Geometry -> GeometryInstance/SymbolGeometry/Solid...
Code so far (the confusing bit is in the foreach loop):
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
namespace scripts
    [Transaction(TransactionMode.Manual)]
    public class CutWithGroup : IExternalCommand
      public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            // Get the currently selected element
            Reference pickedRef = uidoc.Selection.PickObject(ObjectType.Element, "Select an element to cut");
            Element selectedElement = doc.GetElement(pickedRef);
            GeometryElement selectedGeometry = selectedElement.get_Geometry(new Options());
            if (selectedElement == null)
              message = "Please select an element.";
              return Result.Failed;
            // Prompt user to select a group
            Reference pickedGroupRef = uidoc.Selection.PickObject(ObjectType.Element, "Select a model group");
            Group pickedGroup = doc.GetElement(pickedGroupRef.ElementId) as Group;
                Options options = new Options();
                options.DetailLevel = ViewDetailLevel.Coarse;
                options.IncludeNonVisibleObjects = true;
            GeometryElement pickedGroupGeometry = pickedGroup.get_Geometry(options);
            if (pickedGroup == null)
              message = "Please select a model group.";
            // Use a transaction to group cutting operations
            Transaction tx = new Transaction(doc);
            tx.Start("Cut with Group");
            try
                foreach (GeometryObject selectedGeomObj in selectedGeometry)
                    Solid selectedSolid = selectedGeomObj as Solid;
                        foreach (GeometryInstance pickedGroupGeoInst in pickedGroupGeometry)
                            GeometryElement geometryElement = pickedGroupGeoInst.GetSymbolGeometry();
                            foreach (GeometryObject geomObj in geometryElement)
                            Solid cutter = BooleanOperationsUtils.ExecuteBooleanOperation(selectedSolid, geomObj as Solid, BooleanOperationsType.Difference);
              tx.Commit();
              message = "Element cut successfully with group members.";
            catch (System.Exception ex)
              tx.RollBack();
              message = $"An error occurred: {ex.Message}";
            return Result.Succeeded;
DanielKP2Z9V
Sorry for duplicate question. The solution turned out to be using SolidSolidCutUtils.AddCutBetweenSolids instead of BooleanOperationsUtils.ExecuteBooleanOperation.
Full code:
using System.Collections.Generic;
namespace scripts
    public class CutGeometryWithGroup : IExternalCommand
            // Get element to cut
            // Get group
            if (pickedGroupRef == null)
            ElementClassFilter filter = new ElementClassFilter(typeof(FamilyInstance));
            IList<ElementId> dependentIds = pickedGroup.GetDependentElements(filter);
            try
                foreach (ElementId id in dependentIds)
                    Element depElem = doc.GetElement(id);
                    SolidSolidCutUtils.AddCutBetweenSolids(doc, selectedElement, depElem);
                tx.Commit();
              tx.RollBack();
