can't solve failure message
Hello everyone.
I need help understanding how to handle the faileur message bellow:
I just need to use Revit APi to Cancel this message and proceed.
this is my Transaction that causes the error message
using (Transaction trans = new Transaction(doc, "setParameter"))
                trans.Start();
                for (int i = 0; i < x.Length; ++i)
                    GlobalParameter parameter = doc.GetElement(new ElementId(variables.ElementAt(i))) as GlobalParameter;
                    parameter.SetValue(new DoubleParameterValue(x.ElementAt(i)));
                uiApp.Application.FailuresProcessing += new EventHandler<FailuresProcessingEventArgs>(FailureProcess);
                trans.Commit();
and then I'm trying to handle the message, I've Tried without success:
RollBackPendingTransaction
ResolveFailures
Any ideas?
Thank you
jeremytammik
Have you researched what is causing the problem and how to solve it manually through the user interface?
That would increase your understanding and clarify the issue.
Revit is a real-world BIM modeller.
Maybe it is trying to prevent you from creating a model that cannot be constructed in reality.
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy.
I'm using a generative algorithm that is assigning values to Global Parameters and evaluate the solutions.
Some of the solutions it tests are not valid because it breaks some constraints in the project(e.g. eq distances and more). I can manually click on "Cancel" each time this message appears and it will work just fine. But it is very annoying. I just need a way of Cancel or RollBack this Transaction when it causes this kind of error, so my algorithm will not consider this solution.
jeremytammik
Oh, in that case the solution is easy.
Just read through the articles on detecting and handling dialogues and failures and you will quickly find a viable solution:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.32
Jeremy Tammik
The Building Coder
Thankyou,
I've already went through all the documentation but I still have a case of a failure message that cant be solved. Maybe some kind of error that can't be treated with API ?! I'll try to identify what is causing this error and I'll come back again to this post.
ilya.uvarov.uvaTENNT
Hello, everyone!
I cannot find this Failure in RevitApiDocs too.
Did anyone find this failure?
TripleM-Dev.net
Maybe one of these, in the DimensionFailures?
RegenConstraintUnsatisfied Property
RegenConstraintUnsatisfiedWarn Property
I haven't looked further, there could be more reasons for the "Constraints are not satisfied" message.
- Michel
