Can't rotate element into this position
dirk.neethling
Message 1 of 32
dirk.neethling
I created a Family composed of many Sweep and Revolution elements. I chose the mechanical template as it allowed Rotation about all 3 axes. The Family represents a segmental lining ring for a pre-cast tunnel lining.
After instantiating the ring using the FamilySymbol, I need to rotate and translate the ring several times in order to correctly place it adjacent to the previous ring. In fact it needs to be rotated about all 3 axes, and then also aruond ist own central axis.
Following this post,
https://forums.autodesk.com/t5/revit-architecture-forum/rotate-error-quot-can-t-rotate-element-into-...
I unchecked "Always Vertical" and checked "Work plane based"
//Always vertical
famDoc.OwnerFamily.get_Parameter(BuiltInParameter.FAMILY_ALWAYS_VERTICAL).Set(0);
//Work plane based
famDoc.OwnerFamily.get_Parameter(BuiltInParameter.FAMILY_WORK_PLANE_BASED).Set(1);
But it does not resolve the error.
Could anyone please Point me to a solution?
dirk
Replies (31)
Message 21 of 32
FAIR59
that's the referenceDirection.
default placement
placementPoint XYZ(0,0,0)
planeNormal XYZ(0,0,1)
instHandDirection XYZ(1,0,0)
placing the ring vertical:
planeNormal XYZ(1,0,0)
instHandDirection XYZ(0,0,-1)
or
planeNormal XYZ(0,1,0)
Message 22 of 32
dirk.neethling
Does instHandDirection  need to be normal to planeNormal ?
dirk
Message 23 of 32
FAIR59
as I recollect, instHandDirection doesn't need to be normal to planeNormal, but it can't be equal to the planeNormal. You must do some testing to be completely certain.
Message 24 of 32
dirk.neethling
instHandDirection is causing Problems. Is it possible to implement your method without this vector?
dirk
Message 25 of 32
dirk.neethling
Hello FAIR59,
I don't really know what  instHandDirection means or have any use for it, so I try to generate it on the fly in order to satisfy the demands of the method PlaceInstance. Before calling PlaceInstance , I generate  instHandDirection  using,
instHandDirection = RING_VECTOR.CrossProduct(XYZ.BasisZ).Normalize();
Being the result of a CrossProduct, one would assume that the two vectors (RING_VECTOR and instHandDirection) are normal to each other. However when I run the DotProduct of the two vectors [RING_VECTOR.DotProduct(instHandDirection)] , i.e. the projection of the one vector on to the other, I get a residual number:
RING_VECTOR.DotProduct(instHandDirection) -0.000000000000000055511151231257827 double
This causes PlaceInstance to fail in the line,
if (planeNormal.DotProduct(instHandDirection).CompareTo(0) != 0)
return null;
Is there another approach to generate instHandDirection ?
dirk
Message 26 of 32
dirk.neethling
Hello FAIR59,
In your method there is the following line:
return null;
Since the DotProduct is equal to Abs(planeNormal.length)*Abs(instHandDirection.length)*Abs(Cos(AngleBetweenTheTwoVectors)), this can only be equal to 0 if either the angle between the two vectors is 90°, or one or both of the vectors have zero length.
From this I conclude that the vectors instHandDirection and planeNormal do in fact need to be normal to each other.
Or am I wrong?
dirk
Message 27 of 32
FAIR59
First I'd like to mention that the method double.CompareTo() is too strict. It will only return 0 if the 2 doubles are exactly the same. To test if doubles are equal, nowadays I use Math.Abs(a-b)<0.0001.
The method I supplied is a abbreviated version of a method I used in the past. In that version it was necessary that the 2 vectors were perpendicular.
In this version that is no longer required. For the creation of the reference plane and FamilyInstance, we only need instHandDirection and the vector YVec.
So the method will work as long as the 2 vectors not parallel. ( then the calculation of YVec will succeed)
if (planeNormal.IsAlmostEqualTo(XYZ.Zero)) planeNormal = new XYZ(0, 0, 1);
if (instHandDirection.IsAlmostEqualTo(XYZ.Zero)) instHandDirection = new XYZ(1, 0, 0);
if (planeNormal.Normalize().IsAlmostEqualTo(instHandDirection.Normalize()) || planeNormal.Normalize().IsAlmostEqualTo(instHandDirection.Normalize().Negate()))  return null; // check instHandDirection not parallel to planeNormal.
Message 28 of 32
dirk.neethling
Thanks FAIR59, I ended up using
double dot = planeNormal.DotProduct(instHandDirection);
if (Math.Round(dot, 15).CompareTo(0) != 0)
return null;
I calculate instHandDirection using
instHandDirection = RING_VECTOR.CrossProduct(XYZ.BasisX).Normalize();
I tried
but it would fail at times.
I still don't really unsderstand the purpose of instHandDirection, so I hope I am not making a mistake.
Message 29 of 32
FAIR59
what does "RING_VECTOR" represent??
have tried Math.Round(dot,5)  ??
Message 30 of 32
dirk.neethling
It's the same as planeNormal. I use RING_VECTOR for planeNormal and do all the transformations on it (rotations and translations), then I generate instHandDirection like so,
then I pass everything to your method.
Message 31 of 32
FAIR59
instHandDirection should be the required direction of the X-axis of the Family.
Message 32 of 32
dirk.neethling
Thanks FAIR59 for your Support on this Topic!
dirk
