Can't import DWG files into the family document...
LevinLu
LevinLu
 I am using NewFamilyDocument() function to generate a new family document. But I can't import DWG files into this document. Is there a way to achieve it?
jeremytammik
The Revit SDK sample DWGFamilyCreation. It shows how to import a DWG file into a family document, create a new type, and add parameters to it. In this sample, one single DWG file is imported into the family document. The new type is defined, and two parameters are added to it for the DWG file name and creation time.
Quoted from The Building Coder discussion on DWG and DWF Family Creation, July 06, 2009:
http://thebuildingcoder.typepad.com/blog/2009/07/dwg-and-dwf-family-creation.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
LevinLu
Hi, Jeremy
Many thanks to you. I am already using these code from the SDK samples. But I have a new problem now.
I was coding in Revit 2015. When I use the family template from RVT2015, it will show some errors about the "pDBView". But if I use the RVT2014 template, it's working. Is it a bug?
