Can't get References for PickObjects method pre-selection
I have a collection of areas, and want to prompt the user to select additional areas by using PickObjects method. Unfortunately, PickObjects only accepts a list of references, and I cannot find a way to get references to my areas. Thought this might work, but it throws an "object reference not set to an instance of an object" error:
        internal IList<Reference> getRefs(List<Area> areas)
            IList<Reference> selected = new List<Reference>();
            try
                foreach (Area area in areas)
                    selected.Add((area as Object)as Reference);
                return selected;
            catch(Exception e)
                MessageBox.Show(e.ToString());
            return null;
This thread seemed like it might contain helpful info on a similar problem, but the answer in there did not work for me: https://forums.autodesk.com/t5/revit-api-forum/using-elements-selected-before-a-command-is-started/t...
Help would be greatly appreciated!
FAIR59
try this:
 	selected.Add(Reference.ParseFromStableRepresentation(doc,area.UniqueId));
aignatovich
Hi!
Maybe a little simpler, just new Reference(area) instead of Reference.ParseFromStableRepresentation
