Can't Create View Reference
Rob_Bower
Rob_Bower
Can I use the API to create a drafting view "view reference"? I can do ViewSection.CreateReferenceCallout and ViewSection.CreateReferenceSection but I need a View Reference. A circle with detail number and sheet number. Thanks.
jeremytammik
Have you looked at ReferenceableViewUtils?
http://thebuildingcoder.typepad.com/blog/2014/04/whats-new-in-the-revit-2015-api.html#4.07
View API additions
Reference callouts and sections
The new class ReferenceableViewUtils provides utility methods that allow an application to manage reference views such as reference sections or reference callouts.
The new methods
  • ReferenceableViewUtils.ChangeReferencedView
  • ReferenceableViewUtils.GetReferencedViewId
allow an application to read and change the view referenced by a reference view (such as a reference section or reference callout).
http://www.revitapidocs.com/2017/5e671f1d-7423-0a2c-e0c3-915b3dff92ed.htm
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Rob_Bower
Thanks for your suggestion Jeremy but, I'm trying to create a "View Reference" not a "View Section" or a "View Callout" Please see attached file. Thanks.
dnenovMXKU9
Any luck?
jeremytammik
Revit Idea Station?
Jeremy Tammik
The Building Coder
chris.edwardsR3BJR
Hi Jeremy, am I reading this right and we cant programmatically create or set View References between adjoining dependant views? I've just upvoted this as it's something I need on a project with well over a thousand such views across several project files.
jeremytammik
Dear Chris,
I really do not know. off-hand
The best way to find out is to analyse a model yourself, set up the required way, before and after making the required adjustments.
Here are some recommendations on researching how to solve a Revit API programming task:
I actually assume that what you require is achievable programmatically, since many others probably need similar functionality as well.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
